1 members (Scott35), 524 guests, and 19 robots.
#94209 07/18/05 02:11 PM
will a 6-3 romex fit in a 3/4" pvc?
not sure how to calculate the 53% single conductor.
thanx,
h2o
#94210 07/18/05 04:19 PM
I believe for Southern Wire Corp the diameter is .683".
#94211 07/18/05 04:47 PM
Take the largest diameter across the cable. Calculate the cross section area is if the cable were round with this diameter. (PI*D^2)/4
Divide this by the internal area of the conduit. If the answer is less than 0.53, you are good to go.
-Jon
#94212 07/18/05 08:09 PM
Looks like you need to go to 1"
assuming .683 diameter:
Area = Pi*r^2 = 3.14*.3415^2 = .366
assuming sched 40 PVC:
max allowable 53% fill area for 3/4" is .269 (too small)
max allowable 53% fill area for 1" is
.441 (that'll work)
#94213 07/19/05 02:04 AM
thanx guys....
h2o
