2 members (ampherder, Scott35), 228 guests, and 10 robots.
#93131 05/04/05 08:00 AM
How deep should cable TV wiring be buried? Where would I find the code reference?
George Little
#93132 05/04/05 07:07 PM
George:
Article 820 covers coax installation but has nothing about min burial depths. I am tempted to say table 300.5 column 1 (2005 nec). This is a good question ,around here the burial depths average 2- 4" for the local cable co.
Ron
#93133 05/04/05 07:39 PM
Didn't we just answer this question a little while back? The NEC doesn't cover this, I normally use UF depths while the cable guys will just make a slit with a lawn edger and stomp the cable into it. [Linked Image] Of course they couldn't care less when it fails.
Make sure you use flooded cable for direct burial or pulled through pipe underground, not regular cable.
-Hal
#93134 05/04/05 10:16 PM
Hal- It might have been on this forum before, if it was I missed it. And, since you have a handle on telecom stuff (per your bio) what is "flooded cable"?
George Little
#93135 05/06/05 09:53 PM
George,
"Flooded" is the trade name for coax cable which is rated for direct burial. It has a grease of sorts under the jacket to prevent moisture from migrating.
#93136 05/07/05 01:49 PM
Hal
Hal I always use cat 5e for this 'cause it's better'
Should I use flooded 5e? [Linked Image]
Bob
#93137 05/07/05 08:25 PM
Grrrrrrr! [Linked Image]
-Hal
#93138 05/07/05 09:28 PM
Inside joke here I'm misssing. Clue me in please!
#93139 05/07/05 09:34 PM
Your right it is an inside joke.
Hal has a real problem with folks using Cat 5 for every low voltage application under the sun. [Linked Image]
I tend to agree with him, it is more professional to use the right cable for the specific job.
That said I will admit I have used it in a pinch for other low voltage applications if it meant getting the job done and was still code compliant.
#93140 05/08/05 09:52 AM
LOL Bob,
Hell I don't get here that often and even I know what the teeth-gnashing is about!. [Linked Image]
Dig-Dig-Dig
[This message has been edited by Trumpy (edited 05-08-2005).]
