1 members (Scott35), 216 guests, and 11 robots.
#92502 03/19/05 02:30 AM
royta Offline OP
I was contacted by somebody today to install a recep for a pond located in their front yard. The pond is both above and below ground, with four concrete block walls approximately 2 feet tall. The pond measures approximately 12 feet x 12 feet. The owner is also thinking about placing a fountain in the pond. I believe that only Sections I & V of Article 680 apply to this installation. It is purely for decoration and there will be no swimming or wading the pond.
Perhaps I am blind, but I can't seem to find a limitation to how close (horizontally) I can place a receptacle to the inside wall of the pond. Regardless of whether or not it is required, the receps will be GFCI protected.
Can anybody let me know if there is anything special I need to do here?
Thank you.
Roy
#92503 03/19/05 08:36 AM
Y
2005 NEC deals with this
#92504 03/19/05 10:16 AM
royta Offline OP
California, at least the area I'm in, won't be dealing with the 2005 NEC for at least three years. California is finally going full force with the 2004 California Electrical Code (2002 NEC w/ Amendments) on 8/1/2005, but that's an entirely different discussion.
#92505 03/19/05 11:32 AM
680-6(a) of the 2001 CEC covers the receptacle locations for pools or fountains.
steve
Steve
