by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
Hi,
Is there a requirement to have an outlet at a mop sink in a basement of a house?
Is there a requirement for having outlets along counters that are not in a kitchen but a rec room or other area of a house?
Thanks for any replies.
-regards
Mustang
Mustang:
No; but if it is an "unfinished" basement there MUST be 1-GFI recept.
A counter in a rec room poses an interesting point. Not knowing the layout or dimensions of the room & counter doesn't help. The basic 6-12 spacing, and >24" have to be complied with; if the 'counter' fits between the required wall recept, then I will say "NO, you do not need any more by code.
Remember, the NEC is not a design manual, only the minimum requirements for your question.
Hi,
Thanks for the reply...this is a minimum install by design..
only what is required..
there is a 2 foot by four foot counter top for a microwave and whatever else.
i was not for sure if an outlet was required at any counter or not.
this is is finished basement.
I put one dedicated for the mic and one in the center of the 4 foot section.
i can add another if needed.
thanks for the reply
-regards
greg
