#9114 04/17/02 09:38 PM
Redsy Offline OP
Can you mount a porch light on a WP box. Or are there decent looking fixtures designed to mount on WP boxes.
I've been asked to feed an outdoor receptacle for holiday lights from a switched entrance light. The light is mounted on a standard single gang sw. box in brick. The simplest solution seems to be to install a WP box over the old box and drop down with PVC to the new WP receptacle box. But I don't think the fixture will sit properly on a WP box.
Any ideas?
Thanks.
#9115 04/17/02 09:47 PM
Redsy,
Is the switch behind the Fixture?
If it is, why not come off the switch and snake down inside the wall. Poke through a mortar joint with a nipple to a surface mounted WP box.
#9116 04/17/02 09:57 PM
Redsy Offline OP
Bill,
No go. The switch is on a common wall (twin duplex) on the other side of the door. There is no room between the 2 doors to easily come through & mount a box.
#9117 04/17/02 10:20 PM
I've had success with the following Progress brand Luminaires:
P5818-30 WHITE POLYPROYLENE WALL LANTERN $8.00
P5818-31 BLACK POLYPROYLENE WALL LANTERN $8.00
Which mate up beautifully with the following WP box:
Thomas and Betts TR114WH Box Round Weather Proof White W/5-1/2 KO $4.69
I haven't confirmed any other good fits, but it seems to be a standardized thing somewhat...
-Virgil
5 Star Inspections
Member IAEI
