1 members (Scott35), 565 guests, and 35 robots.
Hi,
Does article 410.13 require a space or non combustible material between the housing of the recessed fixture and the joist?
Can you use sheetmetal or sheetrock screws to attach a recessed can to a joist or wood framing member or do they not have to be wood screws?
Thanks for any replies.
-regards
Mustang
Hi, I would have to say no on the space deal, and most of the time I just use the little barbs that are attached to the light it self. or just throw a staple in to hole it up.
You need to look at 410.66 NonIC 1/2 clearance, IC direct contact ok.
