Hi,
I am still trying to pin down the number of Siamese cables I can get in a 2 inch schedule 40 PVC and 2" EMT.
Here is what I have come up with thanks to the previous thread.
SIAMESE CONDUIT FILL CALUCLATION BASED ON 40% FILL
Siamese Cable/Combo (RG59 & 1 Pair #22 AWG 1/2" Diameter)
1/2"=0.50"
Pi R(squared)=(.50*.50)*3.14159=
.785" area.
40% of 2" EMT = 1.342"
1.342"/.785"=1.7 cables
40% of 2" Schedule 40=1.316"
1.316"/.785"= 1.6 cables
I measured the actual cable and it is 1/2".
this does not jive with the follwoing calculations done at Belden cables site:
http://bwccat.belden.com/ecat/images/ConCap.htm
something smells fishy..
Thanks for any replies..
-regards
Mustang
[This message has been edited by mustangelectric (edited 11-01-2004).]
The first thing I notice is you are squaring the diameter, not the radius.
They are getting around this by using 3.14/4 (.785) instead of pi.
Try it using .25 for the radius, squaring that and multiplying it by 3.14
If I was being lazy or didn't have a calculator I would look at table 5, pick a conductor the size of my cable (in your case 2/0 TFE,PFA,PFAH,Z is close enough for guv'mint work at .508), then use the conduit fill table in annex C.
Hi,
Thanks for the reply. I did that already but I know that there are different calcs for straight runs or runs with conduit bends and maybe some other factors I am not quite sure on when dealing with this type of cable.
The calculation I did was from a recent thread in the forum on the same subject.
I will look at the calculation again.
I am not sure if it is right.
Thanks
Greg
Mustang:
1/2" diameter cable has a radius of .25"
.25*.25=.0625
.0625*3.14=0.196
So, 0.196 is your cable's area.
At 40% your EMT has an area of 1.342
1.342/0.196=
6.8 cables allowed in the EMT.
6.7 cables allowed in the RNC.
Ryan Jackson,
Salt Lake City
Hi,
Thanks for the replies. I see the error and appreciate the correction.
What is the difference in the calculation for the Siamese RG59 in a conduit with 3 90's? anybody know?
How do you calculate the Jam Ratio?
thanks again,
Mustang
The jam ratio is the inside diameter of the raceway divided by the outside diameter of the conductor. This value should be 2.8 to 3.2 according to industry representatives. [Linked Image]
[This message has been edited by Ryan_J (edited 11-01-2004).]
Ryan Jackson,
Salt Lake City
Thanks for the great replies..very useful information..
-regards
Mustang
