by NORCAL - 03/19/24 05:11 PM
0 members (), 260 guests, and 19 robots.
#89710 10/16/04 02:15 AM
aldav53 Offline OP
Spas and hot tubs need a GFI, but does a Dry Sauna? This one is 25a 240v. Could not find it in the NEC.
#89711 10/16/04 02:52 AM
e57 Offline
Off the top of my head I say yes, as normal operation involves jumping into the pool afterward. [Linked Image] You know barefoot and wet with sweat, and operating the controls, etc.
As for the code on that, I don't really know.......... Can't find anything either. But for a steam one you do, per manufactures instructions at least.
#89712 10/16/04 11:34 AM
According to the search engine in my electronic 2002 handbook, the word "sauna" does not exist in the NEC. If this sauna does not incorporate a pool or spa I say no.
#89713 10/16/04 12:30 PM
aldav53 Offline OP
I would think if it were a steam sauna you might need a GFI, but a dry sauna probably not.
#89714 10/16/04 10:03 PM
aldav53 Offline OP
I went ahead and installed a GFI just to be on the safe side.
#89715 10/17/04 08:08 AM
V
Dry sauna do not require a GFCI but do require a disconnect or a lockout on the panel breaker if not in sight
#89716 10/18/04 04:14 PM
Y
100% Finnish here , Spent many hrs in da Sauna! Disconnect within sight of the Controller ,No GFI but a Cedar Branch IS Required!!!
#89717 10/18/04 10:21 PM
Okay- I'll bite, What's with the cedar branch and why do you need it? Must be a Yooper thingee.
George Little
#89718 10/18/04 11:08 PM
Self flagelation.
Al Hildenbrand
#89719 10/19/04 08:12 AM
Y
You hit yourself with Cedar Branchs in the sauna Causes the Blood to flow Better,A Finnsh custom. A finn from the U.P.
