468
12
Customer wants a floor plug in the middle of the family room,but it is a concrete slab.Is there any other way to install a plug other than cutting a 3 inch deep channel in the concrete for ridged conduit? There will be carpet over the concrete.
Posts: 7,381 Likes: 7
Shortcircuit: Unfortunately, Not really.
IF the floor is going to be covered with carpet tiles (max 36"x36" tiles), and you can call it "commercial".....there is a system made by Pirelli Cable & Hubbel, flat carpet cable ("FCC" in NEC)
It's use is limited to carpet tiles and comm.
BTW, it's not cheap either.
A 1" deep channel, you don't have to go that deep with RMC. 390.2A Or, a very well trained rat or gopher!
[This message has been edited by e57 (edited 08-20-2004).]
Hey, it is all T and M. Hire a sub-contractor to cut the channel, another to patch the concrete, add 10% "handling charge" and laugh all the way to the bank.
Earl
Posts: 9,928 Likes: 34
I jetted a PVC 19' under my garage floor with a garden hose and hit a 1' hole in the floor (Florida sand). What kind of "dirt" do you have?
gfretwell...good idea with the garden hose..I'll metion it , but there is a lot of gravel up here in Mass! shortcircuit
Yea I tried the washer with a garden hose under a drive way last year.Worked good until 6 months later they called me back seems I created a void under the asfault that collasped later.Guess conrete wouldn`t have the same problem??Most times it has wire supportor rebar. PS after I fixed the dip they had a speed bump(lol)
I was told that the owner found someone to just channel deep enough to lay 14-2 UF in the concrete floor and then they went over it with carpet. I try to do it by the book and some hack ends up with the job.
