Pierre,
Roger
If the 'accessible' is not recognizable, is it accessible?
absolutely, it's just not obvious.
I still haven't seen an article or any wording pointed out, that says an access must be identified or relatively easy to achieve.
I think it's a good idea and an inspector should suggest it, but I still don't see how it could be red tagged.
Let's say I mark the access, but then install "Tamper Proof" screws in the boxes that uses a tool of a type that 99% of electricians don't carry or even own. We have just used these screws on a juvenile detention facility and used them in some boxes that the 8/32's have fallen out of. How would you handle this?
BTW, the last paragraph would be a cause for Justifiable Murder if I had crawled face down in insulation only to find this was the case.
Roger
[This message has been edited by Roger (edited 08-17-2004).]
