667
21
I would like someone to talk about voltage gradients and why the NEC doesn't require this fireplace to be bonded.
Ryan Jackson, Salt Lake City
Maybe to unusual to have come up? Seems like a darn good idea and while you can not make up code you might talk about civil liability in a "unrelated" discussion.
Hi Bob. Beleive it or not, I see this installation on a fairly regular basis . Maybe its a Utah thing? We're pretty romantic ya know. I mean with all of our wives
Ah One is enough 'joy' for me. Before it starts twice as much.
I know the feeling! I figure I might as well poke fun at the stereotype
Is there a plasma teevee {or microwave oven} on the other end?
Posts: 7,382 Likes: 7
Ryan: Just when I thought the jacuzzi with the factory built in plasma TV was the newest "toy" to put in the McMansion, you have to come up with this!
Now, it must be a Utah thing!!
Ryan, ...Maybe its a Utah thing?... Nope, more localized than that. I've never seen one like this
It may not have to be bonded but it should not pass insp. without a hearth per factory requirments of non flamable material
I see what looks like a GFCI receptacle behind the door - a very unusual location. Is that controling the jacuzzi by any chance? One of the reasons that bonding of all metallic parts in proximity of the jacuzzi is not required, is because of the low level of chlorine and the jacuzzi is drained after each use.
Pierre
Pierre Belarge
