Jeff
The NEC is not a perfect document, but any document that has to cover the 'territory' that the NEC covers would not be, try the building codes
Have you read 90.1? The minimum is for safety (NEC), anything above that is for design.
It sounds as though you do care, that is always good to see. Article "PRIDE"!!
Pierre
