The pump and motor needs to be accessible. A removable hatch or door needs to be installed and the receptacle can be located under the rim near the pump/motor. Also, all metal piping, metal parts of electrical equipment and pump motors associated with the tub need to bonded together with a copper bonding jumper that is not smaller than a #8 solid(680-73 99NEC). No disconnect needed.
[This message has been edited by stamcon (edited 01-12-2004).]
