#8692 04/01/02 08:05 PM
Redsy Offline OP
5 mile drive. Disconnect a hard-wired range. Install floor mount receptacle. No need to install the cord on the new range. No problems encountered.
Fill in the blanks please.
$___.00?
[This message has been edited by Redsy (edited 04-01-2002).]
#8693 04/01/02 08:54 PM
3/4 hour + materials....about $100.00
#8694 04/01/02 08:55 PM
Is the new floor outlet fed from the line that fed the hard-wired range, or do you have to run a new line to the panel?
#8695 04/01/02 09:58 PM
$100.00 sounds good.
#8696 04/02/02 07:53 AM
Redsy Offline OP
Would you believe $225.00?
That is what a customer of mine paid someone else. He said the guy was there about 20 min. I'm sure it took a little longer than that though. He couldn't get ahold of me in time for his range delivery, but when I got back to him he asked me what I thought it would cost. I told him about $110.00-125.00.
(NJ)Using the existing cable.
#8697 04/03/02 10:31 PM
$85-$100, depending if it was a 3-wire recpt or 4-wire recpt I had to install. (New or existing appliance?)
#8698 04/03/02 11:45 PM
Boy! That's where I'm out of touch with residential work. Here in Houston most companies will charge a minimum of 2 hours, and at a rate of $50.00 to $75.00 per hour.
Plus material.
Worthological Regards,
Doc
The Watt Doctor
Altura Cogen
Channelview, TX
