by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 260 guests, and 19 robots.
#86587 11/13/03 09:29 AM
Can some explain the current fault conditions.I was explaining to a guy about inrush current on breaker being more than breaker set point for a short time period before it trips.I really don`t feel I`ve done a good job explaining it so I`m asking for some assistance.How does a breaker lets say 40 amp double pole square D home line work to protect agaist fault current.
#86588 11/13/03 09:58 AM
Most convebtional CB's have a thermal component which responds, (relatively slowly)
to lower level overloads in a manner which is inversely proportional (time v. current)to the overload.
There is also a magnetic component, which in the event of a ground-fault or short-circuit, will respond almost instantaneously to this, normally much higher level of overcurrent.
#86589 11/13/03 12:01 PM
Another term for how breakers and fuses react to overcurrent is an inverse time-current characteristic. Simply—the higher the current, the faster the device operates.
Detail: www.usace.army.mil/publications/armytm/tm5-811-14/
Quickie: www.cbibreakers.com/magnetic.asp?menu=sixth
