0 members (), 167 guests, and 23 robots.
#86560 11/10/03 05:44 PM
gserve Offline OP
I have a 100A disconnect on a pole that is going to feed a mobile home.The problem is that the neutral bar doesn
't have room to accommodate both the neutral and the ground connection. Question; Can I attach a bolt-on lug by machine screw to the enclosure to pick up the ground wire. This is the main service and the enclosure is bonded to the neutral bar.
#86561 11/11/03 06:53 AM
Z
Will your POCO let you ground it in the meter base? If they do, your AHJ should pass your inspection. My inspectors would accept the bolt and nut thing, but I know it will take a bashing here.
