1 members (Scott35), 476 guests, and 13 robots.
#86541 11/08/03 09:28 PM
Rabbit, we definately had the same type of weekend.
Roger
#86542 11/09/03 01:26 AM
warlus,
Actually the seaing locknut and the hub have the same rating as far as water protection and the locknut is much cheaper.
Don
#86543 11/09/03 09:33 AM
Don
Thanks for the reply, I've never seen a sealing locknut and by the looks would have never guessed that it would have the same rating as a hub. Seems kind of like a flimsy rig to me and I not sure what would stop water from going thru the threads unless the o ring is big enough to seal around the pipe also?. Interesting [Linked Image]
#86544 11/09/03 09:49 AM
Another thought when punching holes for conductor entry into the side of a cabinet, 312.6 Deflection of Conductors.
I have seen where there is room, and I have seen guys bend the conductors in ways it was not meant to be bent.
There are tables to follow and I bet some don't care - where else do I enter the conductors in the cabinet/enclosure is what I hear.
Pierre
Pierre Belarge
#86545 11/09/03 09:50 AM
The sealant does cut into the threads so it does get pretty well sealed. A Meyers hub is definitely the way to go on top. On the side a sealing locknut is fine. Make sure the conduit enters the enclosure dead straight.
Speedy Petey
#86546 11/09/03 09:52 AM
walrus
From using both I have more faith in the sealing lock nut to stop water than a hub.
I would say a hub provides a stronger mechanical connection as it has more surface area in contact with the enclosure and raceway.
You are correct the seal makes contact with the threads.
That is why I said they can be a bear to put on, I was using a 4" x 6" nipple between NEMA 3R enclosures and threading the sealing lock nuts on the nipple takes wrenches the whole way as the seal presses into the threads.
Once tightened against an enclosure no water is getting by.
The 4" hub on top of my meter socket which has been tightened with wrenches still lets water in. [Linked Image]
Bob
