Paul,
It is interesting, isn't it? In 1905 Nicola Tesla's breakthrough AC motor technology was under patent protection. Polyphase theory was still spreading as the individual technician/engineer tried to wrap his head around AC created
rotary magnetic fields.
The primary use for electric energy was powering lights and motors, and generators had to by very close to their loads.
This book, while delving deeply into AC motors and generators, spends a lot of print on the installed base of machinery that had accrued over the previous forty years, and it is heavily DC. The term
"neutral" has its roots back in these mists, obviously emenating from Edison's 1883 patent of the Three Wire System. This book shows many strange (by today's thinking) distribution schemes that offered incremental performance improvements of an inherently geographically limited system. One huge impediment to commercial viability was, simply, the cost of the copper.
In 1905
The manufacture of 220-volt lamps has been considered a difficult problem to solve under commercial limits.
---Electricians' Handy Book---
With respect to grounding, the Electricians' Handy Book illustrates a couple
ground indicators used to alarm if any "circuit wires" are grounded. Elsewhere in the text:
Earthing Dynamo Frames. -- The windings of a dynamo or motor must be carefully insulated from the earth. The frame, on the other hand, is to be connected thereto. It is pretty sure to have such a connection in any event. Small motors may be insulated altogether.
