0 members (), 331 guests, and 10 robots.
210.70(A)(1)Habitable Rooms. At least one wall switch-controlled lighting outlet shall be installed in every habitable room and bathroom.
Does this preclude the installation of a switch (to control the bathroom light) near the outside of a bathroom door? I am looking at the words "installed in..."
the outlet is inside the room.
Tom Offline
Switch location in this case is up to you. You can put this switch anywhere in the house.
A nice installation might be to gang together all the light switches required by this section in one room. [Linked Image] Homeowner might shoot you, but you would be in compliance with the code.
OK, got it. The light is the outlet, the switch is what is controlling the outlet.
Personally, I don't like a switch outside of that room. You never know who might walk past and turn off the light [Linked Image]
Thanks for the responses!
