Joe, I believe the easiest thing to do in this case (next to flipping the receptacle around) is to just change the cap (dead front of course
). You have to, anyway. Look at the shape of the whole situation there.
If you flip the receptacle, what happens when someone else has to plug something and the cap is "upside down"?
I'd shoot for one of those standard round caps with the wire coming straight out the back, unless you need a right angle because of tight clearances.
In that case, one (maybe more) of the big manufacturers makes a right-angle that can be assembled so the cord exists in your choice of four different directions (right left, up, down). Expensive solution, but hey....
The situation pictured is also typical of a lot of vending machines and refrigerators I see while hanging around and doing my grocery shopping. One particular case I remember in my favorite supermarket was two refrigerators with two caps oriented the same way.
In order to accomodate the two caps on one socket, the store personell used TWO cheater plug adapters to bring the "top" plug further out so it could fit over the bottom one! Obviously that icebox ain't grounded now!!
Joe said:
Whenever I mention some of the problems I discover during my travels, I get a dirty look, they say mind your own business, and why were you trespassing!
Unfortunately that's the way it is. Sometimes it's better (for one's personal safety and wellbeing) to keep one's mouth shut. You try to be a nice guy and you get &#$@.
I don't feel like spending my summers with my jaw wired shut...you know...
[This message has been edited by SvenNYC (edited 08-09-2003).]
