Creighton,
In my opinion the teeth on the locknut are designed to meet the rule in 250.96(A). I believe that this is even part of the listing and when this rule was first placed in the code one of the EMT connector manufacturer's made a point, in their ads, that their locknut was listed for grounding without removing the paint. I see no way that a reducing bushing will provide an adequate fault clearing path if the surface paint is not removed.
250.96(A) ... Any nonconductive paint, enamel, or similar coating shall be removed at threads, contact points, and contact surfaces or be connected by means of fittings designed so as to make such removal unnecessary.
Don
[This message has been edited by resqcapt19 (edited 05-09-2003).]
