#84700 04/25/03 08:20 PM
gserve Offline OP
Has anyone seen a recreation vehicle with a 30A 125V service?
#84701 04/25/03 09:58 PM
Yup. I once wired a 150 space RV park and and had to set up a certain number of each size receptacles; 20amp 120v, 30 amp 120v, and 50 amp 240v. I have a 24 ft.travel trailer that has a 30 amp male plug on it.
Donnie
#84702 04/25/03 10:50 PM
The three travel-trailer receptacle sizes are illustrated in 99 NEC figure 551-46(c)
    [Linked Image from gashog.net]
[This message has been edited by Bjarney (edited 04-25-2003).]
#84703 04/26/03 09:56 PM
Note that the NEMA TT-30R “RV” receptacle is a angled-blade “crowfoot” style—not to be confused with the 3-blade ‘dryer plug’
Rated 125V 30A 2-pole 3-wire grounded receptacle
http://www.state-elec.com/leviton/d503d.pdf page 6 Leviton part no. 7313
#84704 04/27/03 04:43 PM
For examples of NEMA TT-30R receptacles in NEMA 3R raintite-while-in-use enclosures see:
http://www.squared.com/us/depts/mer...2E23FBF4D852568570055DB5E/$FILE/3057.pdf
Square-D catalog no. PAK41CTG and PAK61CTG at http://ecatalog.squared.com/catalog/html/sections/01/17201024.htm
[This message has been edited by Bjarney (edited 04-27-2003).]
#84705 04/28/03 05:16 PM
bj - what is the 'trick' of copying a diagram or illustration from the NEC?
I have no problem copying and pasting text but can't 'copy' the illustrations!!
#84706 04/28/03 08:13 PM
In acrobat reader 5, use the ‘graphic select’ button instead of the ‘text select’ button. Then use edit/copy to copy it to the windows clipboard, and then paste it in a new application. I use the very crippled MS photo editor and save it as a jpeg or gif file, but I think it’ll work the same in word or excel.
#84707 04/29/03 09:41 AM
thank you bj, I'll give that a try and see how successful I am.
