1 members (Scott35), 144 guests, and 9 robots.
#84583 04/12/03 01:43 AM
aldav53 Offline OP
Is there any problem with running romex up under an eve of a home as long as it is out of the weather and not subject to mechanical damage?
#84584 04/12/03 01:47 AM
F
no it is not good idea to run romax for any outdoor appaction the uf wire will be better useage due it say for underground and sunlight restent and i am sure the ahj inspecter will say just use the uf wire other wise run in the conduct with twhn wire as need i am sure few other sparky will say the same answer what i say
merci marc
#84585 04/12/03 05:34 AM
aldav53 Offline OP
They still build residential garages with exposed studs and romex run in them and thats just as much outdoors.
#84586 04/12/03 07:06 AM
Z
Uses not permitted for NM cable, 334.12(A)(10)d, "Where exposed or subject to excessive moisture or dampness".
#84587 04/12/03 07:29 AM
Run it in UF.
