no it is not good idea to run romax for any outdoor appaction the uf wire will be better useage due it say for underground and sunlight restent and i am sure the ahj inspecter will say just use the uf wire other wise run in the conduct with twhn wire as need i am sure few other sparky will say the same answer what i say
merci marc
