1 members (Scott35), 407 guests, and 8 robots.
#8441 03/22/02 02:45 PM
I live in Rhode Island. An average raised ranch style home. i usually charge about $5,000.00 to wire what r others charging for same style house ??????? is my price low or high??????
#8442 03/22/02 03:06 PM
Hard to say with out knowing what you are putting in it.. [Linked Image]
James
#8443 03/22/02 09:17 PM
$100 sq ft for turn key(entire residence0....$3 sq ft for sparky, X2 for plumbers....
#8444 03/23/02 08:22 AM
Here in central MA going rate seems to be 2-2.25 per square foot wired to code. Add 75 each for recessed light, 75 for closet light, more than three heat zones add more, extra flood lights add more.
#8445 03/23/02 09:02 AM
Tom Offline
Here in North Central WV, most of my quotes work out to $2 to $3 a square foot. Do not bid jobs by the square foot unless you are interested in going broke fast.
However, having a rough idea what the square foot price range should be is a good way to make sure you haven't forgotten something in your takeoff.
At one time, I was involved in manufactured buildings. I kept very detailed records on quotations & here is what I remember. The price per square foot is greatly influenced by the floor plan, especially by kitchen counter layout & wall layout as regards to doors. This could swing the square foot price by 75 cents & this was back in the mid 80's.
Another important factor is the size of the house. That $1200, or whatever, for the 200 amp service is a small charge on a 4000 sf house, but raises the square foot price quickly as the house gets smaller.
Most electricians in my area work out a price per opening. Then we have an adder for dimmers, 3 ways, 4 ways, GFI's, WP GFI's, service, air conditioner feed, you get the picture.
Keep the following in mind, the first thing to do is to disable the subtraction key on your calculator. [Linked Image]
[This message has been edited by Tom (edited 03-23-2002).]
