228
Every should know that sec. 680-73 of the NEC says that you need a #8 solid copper wire to bond the motor to the water pipe. My question is would a #6 copper stranded wire be OK? What would be the harm in that? Any thoughts?
I have the feeling that they require solid, because it could oxidize between the strands of stranded. Just my guess.
Russ
[This message has been edited by russ m (edited 02-23-2003).]
I think I remember seeing stamped on the lug on a jacuzzi motor"solid wire only"May be wrong tho. Russell
Posts: 7,382 Likes: 7
Harold: The "book" says #8 solid specifically. I know where you are coming from, and perhaps its the "corrosion" thing if it's stranded....but according to sub-code it has to be!
Every one knows what the code reads, but I sometimes wonder what the intent of the code really is? I wish that I could find out the intent of the code is and where to find it.
Nearest I can tell, that solid #8 requirement kicked in during the 71 cycle.
