197
25
The NEC still uses the term "Flexible Tubing" See 314.17(B) for example. I used it to protect the generator wire on my 1929 Model A. [This message has been edited by Joe Tedesco (edited 02-19-2003).]
Joe, Can we still install K & T?
[This message has been edited by electure (edited 02-19-2003).]
Posts: 7,381 Likes: 7
Joe: Wasn't this stuff used on some K&T installations? I seem to remember a few jobs that had K&T, and in a few places in the basement ceiling, the conductors were in some type of "flex tube", like cotton. John
Here's K&T spliced with BX: A short excerpt from the 2002 NEC: 394.10 Uses Permitted. Concealed knob-and-tube wiring shall be permitted to be installed in the hollow spaces of walls and ceilings or in unfinished attics and roof spaces as provided in 394.23 only as follows: (1) For extensions of existing installations (2) Elsewhere by special permission
ThinkGood: Thank you for the pics.
Joe: Forgot to mention in my above reply, The ads you post are GREAT. John
John: My pleasure. That was in my attic
Joe,
How many times I had to deal with K&T wiring. Yikes. Man that stuff could get scary. I have seen many attics with K&T wiring and there is insulation all around it. ( Sometimes with AL foil backing up against the single wire.)Also how many times I have dropped down a light fixture with K&T wiring only to find 2 bare pieces of copper wire. All the insulation was dried, cracked, and fell off the old RH wire on the K&T.
