1 members (HotLine1), 150 guests, and 15 robots.
#83749 02/19/03 01:32 AM
The NEC still uses the term "Flexible Tubing" See 314.17(B) for example.
I used it to protect the generator wire on my 1929 Model A.
[This message has been edited by Joe Tedesco (edited 02-19-2003).]
Joe,
Can we still install K & T?
[This message has been edited by electure (edited 02-19-2003).]
Joe:
Wasn't this stuff used on some K&T installations?
I seem to remember a few jobs that had K&T, and in a few places in the basement ceiling, the conductors were in some type of "flex tube", like cotton.
Here's K&T spliced with BX:
[Linked Image from 65.108.216.53]
A short excerpt from the 2002 NEC:
394.10 Uses Permitted. Concealed knob-and-tube wiring
shall be permitted to be installed in the hollow spaces of
walls and ceilings or in unfinished attics and roof spaces as
provided in 394.23 only as follows:
(1) For extensions of existing installations
(2) Elsewhere by special permission
ThinkGood:
Thank you for the pics.
Joe: Forgot to mention in my above reply, The ads you post are GREAT.
Look here for more ads! Thanks for your kind words.
https://www.electrical-contractor.net/Nostalgia/Catalog1-S.htm
John:
My pleasure. That was in my attic [Linked Image]
Joe,
How many times I had to deal with K&T wiring. Yikes. Man that stuff could get scary. I have seen many attics with K&T wiring and there is insulation all around it. ( Sometimes with AL foil backing up against the single wire.)Also how many times I have dropped down a light fixture with K&T wiring only to find 2 bare pieces of copper wire. All the insulation was dried, cracked, and fell off the old RH wire on the K&T.
320,019 Are you busy
245,207 Re: Forum
228,636 Need opinion
