228
In my Int Fire Code book they list what kind of fire systems are required per what kind of "Group" the building is. Where can I find the definitions for the different groups? Ex Group A, Group E, Group R1 etc.
It sounds like you would have to try the NFPA (National Fire Protection Association). However the information is not free. It will cost you, or you could call up an architect. Or a fire sprinkler contrator. Scott
Which int fire code book are you using? The international building code has definitions as to group types for buildings in the book.
Ron
Posts: 7,382 Likes: 7
You should be able to get the info you need from the building dept., or building inspector in your locality, or state. Also, the Fire Marshal (Fire Inspector) should be able to answer you.
It is the 2000 International Fire Code. Big red book. If I would have looked in the front, under definitions I would have found it. Sorry to bother you
When all else fails...Read the instructions. Scott
Check with your local BOCA chapter for the exact listings, however a brief description is: A= Assembly (5 different classes) B+ business..........E=Educational..... F=Factory (2 classes).....H=High Hazard....I=Instituional(3 classes)....M=Merchantile....R=Residential(3 classes)....S=Storage (2 classes) and U=Utility. If you want more info, I will get it for you.
Harold
That previous post was suppose to say B=Business. Also by different classes A-1 is theater, A-2 is night club, A-3 is restaurant, A-4 is church, and A-5 is outdoor assembly. R-1 is Hotel, R-2 is multi family and R-3 is one/two family dwellings.
Harold
