1 members (Scott35), 540 guests, and 32 robots.
#82512 11/19/02 10:22 PM
I have an opportunity to do a job for a body shop. It is to wire a new room that has been built in the existing building. It will be the place where paint is mixed and colors added, etc. Can anyone help me with code references for any special requirements? My code knowledge is weak in this area. Thanks, WW
#82513 11/19/02 11:40 PM
I would start with article 516.
#82514 11/20/02 05:36 PM
Like Spyder said the NEC, and a conversation with the AHJ, before you start or commit yourself. Are there any "plan" requirements where you are to get the necessary permits? Here, a detailed plan by a PE or Arccitect would be required with the permit application. Then it goes to plan review, and the AHJ doing the review asks his questions to the PE, Architect, and/or EC.
Sounds like a pain in the butt, but the liability goes to the PE/Architect 1st.
#82515 11/20/02 11:15 PM
This is in an area of the county where, believe it or not, there are no codes or inspections. Article 516 deals with spraying, but the spray booth is already built. This room is just for mixing and storing paint. If you think about it, the local hardware stores, or the big orange box, don't really have a separate area for this, they mix and store paint right in the middle of the store, with no special precautions that I have noticed. I want to ask some of the inspectors in other areas that I work, but they are busy. They are usualy nice enough to answer questions about their own town, but, unless I get an opportunty, I don't want to wear out my welcome asking questions that pertain to another jurisdiction. Thanks for the replies so far.
WireWrestler
(eyes blurred, and head still in code book!)
#82516 11/21/02 12:20 PM
The big orange box has enough air exchanges that the fumes cannot accumulate like they can in an enclosed area.
Donnie
#82517 11/23/02 12:10 AM
You will absolutely need some of the following:
Switch-less lighting.
Air exchange system.
Rigid pipe installation or PVC / with sealant.
Explosion proof fixtures.
Arc fault breakers.
Etc.
Look up article 516 of the 2002 Code Book.
#82518 11/23/02 09:40 PM
The job is done. Thanks to all for your input. I used all rigid conduit with explosion proof junction boxes. The customer had supplied an explosion proof light fixture. The ventillation was done by others. All switching is outside the room. I spared no expense (so I can sleep at night!).
WireWrestler
#82519 11/23/02 10:10 PM
Sounds like a job well done !!
Donnie
