Nick, what are these metal plates you speak of? Are they "home-made" or an available product from a distributor? Also, I assume the ears must be cut off the devices to avoid interference with the sheetrock. So if the edge of the sheetrock does not line up exactly flush with the box, won't you have a "fit and finish" problem come trim-out?
