As the other SoCA Scott says, interiors not set until the "Mud Monsters" are done. This also cuts down on C/B theft, which is quite a problem here. The exception to this is the EG bar, which we put in and terminate so that a good connection to the enclosure is made before the onslaught of taping and texture. All the cardboard and plastic we can put over the front of the can doesn't seem to deter the drywallers from their mission to spill and fill... everything
