1 members (HotLine1),
210
8
110.12 Mechanical Execution of Work.
Electrical equipment shall be installed in a neat and workmanlike manner.
What does this mean to a "Qualified Person?
I try to be sure that the installation is done right the first time!
To me it means "TAKE PRIDE IN YOUR WORK" no matter were you are working make it look like it was done for a palace. Remeber your work is a direct reflection of you. Every time we bring a machine tool to our building from the corporate shop i cant believe some of the wireing the veteran maint guys do. no pride in there work.
true jlhmaint, yet to a 'qualified' person the neatest job may incorporate the worst 'workmanlike' electrical design.....
Posts: 7,382 Likes: 7
Oh Well, here goes: Neat and workmanlike should mean that the job was done professionally, and LOOKS it. Level, square, plumb, straight, etc., etc.
Pride in your work? That's my company policy Do it right the first time? Definitley. There's some shoddy work around, and it's to bad that it reflects on the trade in general. HotLine1 John
Reprinted from the neca site. The American National Standards Institute (ANSI) has approved NECA 1-2000, Standard Practices for Good Workmanship in Electrical Construction. Envisioned as the ‘centerpiece’ of the National Electrical Installation Standards series of publications, NECA 1 defines what is meant by installing equipment in a “neat and workmanlike manner” as required by the National Electrical Code, Section 110-12.
Subjects covered include receiving, storing, and protecting construction materials on site, properly mounting and supporting electrical equipment, installing raceways and conductors, and Americans with Disability Act Guidelines (ADAG) for locating electrical products and systems. NECA 1 is the sixth NEIS to receive ANSI approval. It will be available for purchase in August.
Ron
Posts: 440 Likes: 3
I agree with all that was stated above. Let me throw another twist into this mix. Neat and workmanlike is defined by the inspector who passes or fails the installation. When an installation passes inspection, it is by virtue of that fact, neat and workmanlike. We all know that any self respecting inspector would never pass an installation that wasn't up to code (neat and workmanlike). It is also the electrician who installs the work. Here in Texas, as many of you may know, there is not a state license for electricians. Therefore, many areas don't have an AHJ. In those areas with no inspections, the electricians define what is neat and workmanlike.
Neatly, Doc
The Watt Doctor Altura Cogen Channelview, TX
Posts: 2,236 Likes: 1
Oh the venerable 110.12... It was the first code I memorized as an apprentice, and became my favorite (and least favorite) quote in the entire book. The subjectivity of the wording lends to all sorts of interpretation, and if the AHJ was in a particularly bad mood that day, any installation could fail 110.12 . There's nothing more that I could add, but that I'm glad to see the quotes and better explanations of this. I even asked an inspector once if he was going to bust me on 110.12 for having my conduit a little skewed... He just looked at me for a moment with an odd look on his face, and said "Nah..."
as opposed to? !!OFF WITH HIS HEAD!!!yer far to self-critiqing my friend....'Neat & Workmanlike" , IMHO, is when other electricians say 'oooh!'
I had a problem with some PVC conduit in a garage/home workshop a few weeks ago.
I carefully fitted the spacer saddles in line with the brickwork across the end extension and installed the conduit nicely parallel with the joints. When I stood back and looked at it from a distance the conduit (white) was obviously sloping downhill.
The problem was that the brickwork was not horizontal. If I adjusted the conduit with a spirit level to get it dead horizontal, it looked fine from a distance, but up close it looked bad because it didn't line up withe the brickwork.
No way to win on that one!
Pauluk,
When I run into situations like you describe, all too often I might add, I always follow the building lines. It's likely no one will ever put a level on your pipework, but if it looks crooked to the eye everyone can see it.
JMO GJ
Lostazhell
