211
Can a switch be within reach of a shower door/curtain?
Sparky, The code only says it can't be in the shower space. It is permitted to be within reach. 404.4 Wet Locations. A switch or circuit breaker in a wet location or outside of a building shall be enclosed in a weatherproof enclosure or cabinet that shall comply with 312.2(A). Switches shall not be installed within wet locations in tub or shower spaces unless installed as part of a listed tub or shower assembly. Don(resqcapt19)
A rare case of our "code" being stricter than the NEC!
No switch here is allowed to be within reach of anyone in a bath or shower, unless it's a ceiling-mounted cord pull type.
'66 has a pic on his site of a switch within easy reach of someone in the tub.
[This message has been edited by pauluk (edited 05-15-2002).]
Posts: 2,236 Likes: 1
Paul, the pic you speak of was presented in a thread here as well. Click Here! What about sconce lights? I've actually installed a pair of sconces in the tub space in the last two houses I've wired. It was in the plans, and I can't find anything in the NEC to prevent it. They are on GFCI protection, however.
'66 Actually there is a code reference for your sconces actually not the sconces but in reference to :
(3) Bathroom Branch Circuits. In addition to the number of branch circuits required by other parts of this section, at least one 20-ampere branch circuit shall be provided to supply the bathroom receptacle outlet(s). Such circuits shall have no other outlets.
Exception: Where the 20-ampere circuit supplies a single bathroom, outlets for other equipment within the same bathroom shall be permitted to be supplied in accordance with 210.23(A).
.. So the sconces are ok, as far as I cant tell as long as it does not exceed 50 %(210-23)..
-Mark-
Pardon my ignorance, but what exactly is a sconce light? (I seem to be lost mid-Atlantic in terminology again!)
Virgil, Completely off-topic.... Loved reading your happy/sad story about Murphy. I adore cats myself, and I know the feelings you go through when you loose such a friend.
Paul, it's generally considered a fixture ( luminare) that mounts to the wall instead of the cieling..... there would seem a bit of confusion ( mostly on my part) as to the 'shower space' which is 8' above and 3' surrounding the tub rim, as opposed to the space within the shower itself.
Thanks Paul, up to 6 dogs and 7 cats now, the pets section on my web site needs updated...
Dern critters are eatin' me out of house and home!
But I love 'em all...
Wow, that's some managerie Virgil! Only one cat here at the moment; rescued him as a kitten in Ireland about 3 years ago. Lost another after nearly 9 years to a heart defect -- It's so heartbreaking. I guess I should have looked up "sconce" in the dictionary before. According to my Concise Oxford version: sconce: n. Flat candlestick with handle; bracket candlestick to hang on wall [Middle English from Old French esconse lantern, or from medieval Latin sconsa from Latin absconsa fem. p.p. (as n.) of abscondere hide.]
O.K., I live and learn. It makes sense now. [This message has been edited by pauluk (edited 05-17-2002).]
