Electricians revenge
0 members (), 205 guests, and 12 robots.
#80325 03/28/02 11:03 AM
hi all i haven't wired many pools but im pricing one just wanted to see what others r charging for the wiring of above ground pools like 24' round. thanks in advance
im charging $400.00 thats all materials permit and labor.
#80326 03/28/02 10:55 PM
Seems low. How far is the pool from the house?
#80327 03/29/02 10:22 PM
20' away
#80328 03/30/02 12:25 AM
What else is invovled? A timer? What brand of breaker in the panel? How many obstacles inside the house to get to the panel? Are you digging the trench yourself? Is there a helper involved? etc etc
It's hard to make a comparison to that price without more details. Since I'm from RI (originally), I know the market well, but again, just provide more info on what your price involves.
Peter
#80329 04/01/02 11:48 PM
sq d panel they r digging trench panel close to outside wall where im running pvc pipe.
#80330 04/02/02 08:46 AM
What I would do for basic installation. Rx from panel to jbox. From there 1/2" PVC to a wp switch box with a single pole switch mounted to a 4x4 post, above that wp box with a 20 amp twistlock recept. Run bond around pool to motor,install gfi breaker. Also I wouldinstall a general use gfi on the house to comply with 680-6a. Price tag materials $150 Labor 5 hours @ $65.00 permit $75 total $550.00
#80331 04/02/02 11:51 AM
scott what's rx i usually run mc from panel to jbox then 1/2 pvc to a 4x4 post and use a 2 gang plastic box with twist lock and switch and install gfci breaker and bond pool of course to motor.
#80332 04/02/02 10:05 PM
Hey, try 3/4" rigid for the underground, less depth always. 3/4" is my minimum UG feeds for any distance and even 2/3 wires, always makes life easier now and in the future. Bring the feed into the bottom of your box, and in the next hole in the box is my 3/4" rigid beat into the ground 5/6' for stability, very clean install, and some additional grounding help. I always use double boxes and deep. If you feel like it, back-up two single deep boxes, switch on back, outlet facing pool. Careful of the general use GFI rule though.Typically don't use GFI breakers due to cost, usually use a faceless next to general use GFI.
#80333 04/03/02 12:54 PM
DB Offline
Running 3/4" cndt is good advice. Also, consider running the next size up wire (or calculate it). In your case your only going 20ft from the house - not bad.
In some cases it the run could be a couple of hundred feet - if the service panel is on the other side of the house and you have to go around a few things on the way to the pool pump. This all has to do with voltage drop. Many homes have low voltage at the service drop already. It can be within ANSI spec and still be too low to allow you to drop much more and still serve high loads.
DB
#80334 04/04/02 09:04 AM
I like the GFI C/B idea myself, rather than the GFCI outlet.
Even if the GFCI outlet trips, you still have non-protected conductors present in the box. As badly as homeowners can beat up a w/p cover and gasket....well, you see.
