Here in our area, 2 ground rods would be required. One at the pole and one at the barn. If either of them reads over 25 Ohms when tested, then a second one is driven at that location. Ground rods are basically for lightning protection. Your 'ground' is being supplied with the power companies feed via the grounded(neutral) conductor.
