Electricians revenge
0 members (), 205 guests, and 12 robots.
#78765 10/22/01 09:28 PM
hotwire Offline OP
A outside wall mounted 100amp 3meter/breaker-combo from a
gas meter, replacement for single meter serving 3 apartments
#78766 10/22/01 10:25 PM
Table 110-26(a)
What is the voltage to ground?
Assuming 120V- 3ft deep by 30inch wide or the width of the equipment, which ever is wider.
#78767 10/22/01 11:38 PM
Hotwire,
Where I am there must be a 12 inch clearance from the Gas. You should ask your local utility what they require.
