Aah, the old 6 penny 2 pole (or 3 pole).
Why do the holes run all the way through the handles, anyway? The factory usually only uses the first 1/8" or so.
As for the oversize neutral idea (I've already said I don't do this), isn't that doing the same thing that you're doing running to the neutral bar in a subpanel?
[This message has been edited by electure (edited 10-17-2001).]
