Electricians revenge
1 members (Scott35), 183 guests, and 10 robots.
#78141 08/21/01 06:00 PM
MOELLER Offline OP
IN THE PAST I HAVE ONLY WORKED ON SYSTEMS 600V AND LESS. I AM CURRENTLY WORKING ON 1000V SYSTEM AND NEED TO KNOW IF THE REQUIRED SPACING PHASE-PHASE AND PHASE -GROUND IS GREATER.
THANK YOU
#78142 08/21/01 08:43 PM
MOELLER;
read about it in 110
#78143 08/21/01 08:46 PM
Ditto, Sparky, but it is 110-36. I also suggest if you are going to make a habit of over 600V you get a copy of the National Electrical Safety Code, which goes a bit deeper into clearances, also check with OSHA part 1926
#78144 08/21/01 08:47 PM
Geez fat fingered non proof reading....
110-34
