1 members (Scott35), 524 guests, and 23 robots.
#77476 06/10/01 06:46 AM
cinkerf Offline OP
A Concrete cutting saw has a dual voltage rated motor. Nameplate values: 120/230V. 28/14A. 1Ph. 3H.P. The building voltage system is: 120/208V. 3Ph. 4Wire. For this job we do not want to install a boost transformer necessary to supply 230 volts to the motor. We are just going to supply the motor with 120 volts. Is my drawing compliant with the Code? http://www.geocities.com/cinkerf/saw.html.com
#77477 06/10/01 06:56 AM
cinkerf Offline OP
Sorry about the UBB Code error. I usually use HTML. I'll try again. http://www.geocities.com/cinkerf/saw.html
#77478 06/10/01 08:02 AM
It looks just right to me
#77479 06/10/01 06:41 PM
Anonymous
Unregistered
