1 members (Scott35), 528 guests, and 22 robots.
#76518 02/18/01 02:28 AM
This lightbar is mounted on a Bathroom ceiling.
Is this a bad idea? What do you think?
#76519 02/18/01 07:50 AM
Bill;
I hear that style referred to as "Hollywood" lights. I've had a number of cases where I installed them surrounding a mirror.
Without getting off into a "rating, listing" type of thread here, I'll say it's has some practical pitfalls.
The first is that bulb heat will attract condensation , more prevalent in the position they are in
The second is simply head room. Head butting an element can do bad things to your makeup.
#76520 02/18/01 11:43 AM
Sparky,
No, there's no headroom problem. I was wondering if the heat to the fixture wiring would be a problem. There is an insulated attic area above and it may not be 90C wiring. That was my concern.
#76521 02/19/01 08:45 PM
Oy the heat! [Linked Image]
most fixtures have that insulation , if this does not then it may create problems.
That makes this more a "rating" "listing" Q
thanks for the hint....
