by NORCAL - 03/19/24 05:11 PM
1 members (gfretwell), 32 guests, and 14 robots.
#76283 01/09/01 08:30 PM
sparky Offline OP
680-6(d) Motors other than Dwelling units.
Wiring supplying pool pump motors rated 15 and 20 amps, 125 V or 240V, single phase, whether by receptacle or direct connection, shall be provided with ground-fault circuit interupter protection for personnel.
Ok fine, i do a call to a municipal pool who's 3-phase motor has taken many a bath in the pump house due to bad pipes, only to find that #1-no GFI #2-NEC says to H____with it & #3-can't get a 3 ph GFI
So does 3 ph power somehow mix with H2O safer?
Would you swim in this?
[This message has been edited by sparky (edited 01-09-2001).]
#76284 01/09/01 11:00 PM
doc Offline
sparky,I don't understand the code myself,and off the subject but here is another kicker that makes no sense in a public pool there is a minium and maxium amount of chlorine that can be in the water however in your drinking water there is a minium but no max on the chlorine,I have seen children actually bleached out from chlorine in our drinking water this is from bathing in it makes no sense
#76285 01/10/01 08:19 AM
sparky Offline OP
bleached & charged kids, go figure [Linked Image]
I'm trying to look up old ROP's on this, as it did not exist before '99. Call me paranoid, but i'd rather have GFI protection on this, if it exists. [Linked Image]
