I think this is where the roto zip is the best tool for the job. I can cut the wall while holding the vac to suck up the dust as I go. You need to use a tile blade for the plaster and then swap out for a wood blade to finish it up. I have two roto zips to speed up this process if I am doing a lot of them.
