It would not surprise me if some of the projectors you use require multi wire branch circuits.
Actually, none of the newer ones do.
The manufacturers realized that the xenon lamp ignitors and house lighting dimmers cause too many noise and harmonics issues, with the modern electronic automation systems.
However, it was at one time common practice to have projection consoles with built-in subpanels to serve the projection loads.
As we've discussed before, my bias is against MW
branch circuits, where as Reno and many others have related, trouble can easily arise.
[This message has been edited by mxslick (edited 01-03-2007).]
