Electricians revenge
0 members (), 192 guests, and 14 robots.
#73028 12/15/06 01:43 PM
I have 4 old-style green porcelain lamp shades, 18" diameter. They are missing the screw-on piece at the top to which the bulb is installed and from which a conduit hanger is attached. The diameter of these threads is approximately 2 3/4". I'm looking for a source for these parts. Thanks for any help!!
#73029 12/16/06 12:32 AM
I've seen some that are similat to what you're describing and I'm not sure if I remember right but it seems like they were made by crouse hinds. Hope this helps and that I'm not steering you in the wrong direction.
#73030 12/17/06 09:06 PM
CF, are these what you're talking about? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140064505307&ssPageName=ADME:B:EF:US:2#ebayphotohosting
IF so do some more searching on e-bay. I saw some others there for a little more money. After some reflection I now think that they were made by GE or Westinghouse, not Crouse Hinds.
#73031 12/17/06 10:54 PM
I have four of those myself, exactly like the ones on ebay. They screw perfectly into a vapor proof fixture base, but I too would like to find the original type parts.
#73032 12/24/06 03:09 PM
FWIW the Applebees resteraunt here uses a similar fixture so someone is still making them so if you're interested in new they're still available.
