by NORCAL - 03/19/24 05:11 PM
0 members (), 263 guests, and 17 robots.
#72582 12/04/06 07:52 PM
Any advice on finding replacement fuses for 60 year old "DF" series(ex: DF8144-1 200A 230V 3Pole 30H.P.) from Square D? Square D told me that they were Class H fuses but I can not look at the fuses themselves without killing power to at least some part of a highrise apartment complex (sorry about that in the elevator). Thanks.
You're going to have to kill the power some time or other. The HP rating of the disconnect, it's amp rating, etc. aren't going to give you the answer.
Shut it off, open it up, and look.
Mike:
Welcome to ECN. Your profile does not include any info on your profession.
You may want to call a Lic Electrician to determine a solution for your fuse situation.
The power will have to be interrupted to remove/replace the fuses.
http://ecmweb.com/news/electric_specifying_right_fuse/
http://thefusecompany.net/ClassH.htm
http://www.relectric.com/Catalog/Fuses/Bussmann/Fuses/Time--lag/fAtt2/fAtt3/fAtt4
Here are some links. I can tell you the fuse case on the renewable make great drill bit holders for the tool pouch. Rod
LK Offline
Michael,
Welcome to ECN, I would recommend, you have a Licensed Electrical Contractor look at your problem, if a fuse opened, other issues may have caused it to open, in a High Rise building, the safety of many is at stake.
