by NORCAL - 03/19/24 05:11 PM
0 members (), 248 guests, and 16 robots.
#72390 11/29/06 12:14 PM
Mike, that is correct, but why would you want to dig further and use more conductor?
Roger
#72391 12/02/06 12:52 PM
e57 Offline
If this is a duplex with two owners, then as the owner of the other unit, I am not going to permit you to come onto my side to make this connection.
Don
They maybe they dont let you access that sewer clean-out on thier side when you need it? [Linked Image]
Either way the connection needs to be made <5' from entrance of the building, if the two units are the same structure then they are treated as one. I would also assume that it has only one service entrance, and only one water feed?
