1 members (Scott35), 530 guests, and 20 robots.
#72218 11/21/06 11:01 PM
Jps1006 Offline OP
The big thing around here is putting light rope tucked inside of crown molding on a tray ceiling. I had a customer ask about it and I told her I don't like it because of the ugly yellow color and the fact it doesn't put out much light. She wants some alternative suggestions.
What are some good altermatives to get a better effect. I was thinking maybe single lamp T8's with a dimming ballast. The tray will be a bout 16" deep on the bottom, so maybe 8-12" deep up top.
What have you guys done and how did it work out?
#72219 11/21/06 11:32 PM
Juno Track 12 or halo simular but it can get costly once you add the transformer. I hate rope lighting too but you will never find an alternitive near it's low price. Here is all kinds:
http://www.ccl-light.com/docs/indoor/rope/index.html
I looked at the strip lights before but never installed them.
#72220 11/22/06 09:20 AM
These take some research and planning but they are thre cats meow!
http://www.luxeon.com/products/family.cfm?familyId=3
#72221 11/22/06 04:20 PM
Jps1006 Offline OP
Thanks for the ideas guys. I'm open to the strip xenon in Tom's link. I'll price it.
Twin City, have you installed those (in your link) before? Do I need to build a circuit out of components or is it all plug & play? (or a little of both?)
#72222 11/22/06 07:57 PM
Try linear lighting from luciferlighting.com.
Navigate to "light strips" and then get the spec sheet for linear lighting. Very easy to install, dimmable, NOT CHEAP.
#72223 11/23/06 10:43 AM
Jps
Yes, I have installed Luxeons before in marine, automobile and home applications. You can buy several different types of plug and play style circuit drivers/enclosures for these or build your own. Just Google them once. Phillips manufacturing makes Luxeon. They are the brightest LEDs available boasting a 100K hour life span (if properly heat-sinked). The backlighting application that you are looking at is a perfect apllication for the 1 watt Luxeon emitter. Use one of the "dimming" style drivers and space them about 10" apart. Without sounding too much like a salesman, I must say I beleive these are the future in lighting. The only problem right now is cost but, they are coming down in price every year. Cheapest I can find one "raw" 1 watt Lux. is at Future Electronics for $6.50 a piece. I've built 3 different portable work lights using these. One uses a 12 volt 7 amp hr. rechargable battery with 6 Luxeons. It is the perfect work flood light. It's very bright and lasts days without a charge. Every electrician who borrows it wants one. I am currently building one for a fellow sparky right now. Ok - I'll admit it, I'm a Luxeon freak. You will be too after you play with these for a while. John
#72224 11/23/06 10:48 AM
Almost forgot, you have to check out some of the photos in their application page...
http://www.luxeon.com/gallery/?filter=applications
Need I say more.
#72225 11/23/06 01:03 PM
try led rope lighting
http://www.ledlightworld.com/ledrope.html
many colors
Denny
