1 members (Scott35), 143 guests, and 11 robots.
#71943 11/11/06 07:36 AM
Would anybody be able to give me some technical answers. I tried to connect a gas furnace last night and didn't know how to tie in the auto water feed or the make up air fan. The wiring diagram confused me. I am going to go back today around 10:30 but Tech reps aren't available till Monday. Any Help would be greatly appreciated. My phone number is (removed by Roger) if you wouldn't mind giving me a ring.
Bob
If anyone can help, please contact Bob by e-mail for his phone number. Roger
[This message has been edited by Roger (edited 11-11-2006).]
BobV
#71944 11/11/06 10:28 AM
What kind of gas furnace has a water hookup?
Is this a boiler? What is the "make-up-air fan? Is that a combustion air fan in the furnace room or a unitary part of the "furnace"? Most if not all furnaces have their draft inducer and blower motors internally wired in the equipment harness, it is not usually part of the electrical connection, as part of their aga approved status. There is usually one point of connection for line voltage and one point for class 2(thermostat, control). Is the water hookup for a humidifier, or is this a cutoff for a steam boiler? If this is boiler wiring, let the heating guy do it, this is generally not covered by a sparky's liability insurance.
#71945 11/11/06 10:39 AM
Hey Bob- here's a site for burnham tech info- You'll need a model no., but if you can get me this, I'll call you back as we discussed and we can go over the techy. http://www.burnham.com/IO_Manuals.cfm
#71946 11/11/06 08:34 PM
I started over today by hooking the gas fired steam boiler up without the accessories and it works fine. The fan is a make up air fan that has 120v supply (I think that is supposed to be constant) and 3 terminals marked T1, T2, T3. These terminals must have some way of both controlling when the fan comes on as well as providing a safety so that the boiler doesn't come on without it being on first. The other accessory is the water filler for automatic water replacement as the boiler water level gets lower. This is supposed to tie into the lower water level control where it appears I also need an additional 24v source to provide power to the water filler valve. I will contact Burnham Monday for the answer so that I don't waste any more of your time with incomplete descriptions but thanks for the help. This sight has really impressed me with the amount of good samaritians that can be found here.
BobV
#71947 11/12/06 07:43 AM
I hope you have a heating professional there to analyze the flue gasses to make sure that the gas and air is adjusted properly. The reason that there is a makeup air fan is probably that there is not enough air to completely supply combustion air plus draft air so that the exhaust gets out of the house.
I HOPE THAT NO ONE IS IN THE HOUSE IF THE FURNACE IS RUNNING WITHOUT SUFFICIENT MAKE UP AIR. CARBON MONOXIDE POISONING IS A REAL AND DEADLY POSSIBILITY !!!!!!
Larry C
#71948 11/12/06 11:09 AM
Is it a Field Controls fan in a can?
#71949 11/12/06 09:19 PM
LK Offline
"If this is boiler wiring, let the heating guy do it, this is generally not covered by a sparky's liability insurance."
I am trying to post the Pic's of a building, where boiler, ran out of water.
#71950 11/13/06 06:14 AM
e57 Offline
Boiler ran out of water?! Well thats just a space heater... [Linked Image]
#71951 11/13/06 08:53 PM
LK Offline
You got that right, to space is where the building went. I think they put all those extra wires, and switches on boilers just to confuse you.
