1 members (Scott35), 542 guests, and 43 robots.
#69866 09/21/06 11:14 PM
eswets Offline OP
I have never had to wire an automatic faucet before, and the plumber has no spec sheet. I am finishing the rough tomorrow, and I don't know what to do for the faucets? Any help?
Thanks
eswets
#69867 09/22/06 12:57 AM
Depends on the faucet. Most likely the sensor is in the faucet and all you will need is a receptacle under the sink. There are some that have a separate sensor that goes on the wall, but you could always fish that in later.
Sixer
#69868 09/22/06 08:44 AM
Make sure you check the specs provided !
Most of the ones I have dealt with give an EXACT location for the electrical connection. Sinks are easier then toilets and urinals.Toilets and urinals have a location tolerance of about 0% they must be dead on.
#69869 09/23/06 09:33 PM
the ones I've worked on needed 24volts under the sink
